Heater hose routing
matt19857 said:
I am not sure how this would effect cooling.
When the heater valve is closed, no water flows in that circuit anyway. If you use a long hose you don't have to break off the fitting coming out of your head, or deal with the other end, which you can't really plug anyway.
You can also just get a piece of tubing to connect the two shorter hoses and bypass the heater connections through the firewall. That way, you can put the heater back in if you ever want to...
Just a suggestion.
