Heater hose question
Colorado
Hi all!
I am replacing my heater t’s and hoses. It looks like the coolant dripped down onto the lower hoses which I tried to order but are discounted. Does anyone know if I should go with aftermarket hoses or? I think the part numbers is 8720860611. I attached some photos I can try to get better ones . I really appreciate the help.
As long as the hose is proper heater hose (heat and pressure rated) then it should be fine.
It’s the longer hoses underneath the heater hose. I tried finding other threads but no luck. Has this happened to anyone, as far as the coolant dripping down to lower hose and burning them?
It's hard to tell from your photo as the auto focus hasn't shown where the actual problem is. Are they still leaking? Are you losing coolant?
So I’ve had the cruiser for a month just recently I ordered the hoses and t’s it is leaking from the t’s and the lower hoses. I can try to get a better picture . That’s the hoses attached that the rubber is burnt. May be hard to tell in the photo
Tried attaching another photo to the post didn’t work. Any idea?
Coolant shouldn't burn anything. It may discolour stuff and peel paint but not actually burn anything. As I said it's difficult to tell from your photo but it's obvious that you need to repair the leak. Seeing how you've only had the vehicle a short time I'd be giving the cooling system the once over and drain, flush and refill with the correct coolant. There's no reason why you can't use aftermarket tees and hoses. Make sure however that you use the correct coolant for your engine, it is crucial.
These were all the hoses, clamps, and tees to do the job a couple months ago...can't imagine any of it has been discontinued since.
(from Partsouq, and ordered 4 tees to have some on hand)
Thank you I have a 2000 LC, I’m not sure if those lower hoses are in there should be two hoses that go below. Any idea ? Sorry I’m new :(
It’s part number , I need two days they are discounted on every site I’ve checked any idea or just go with after market?
8720860611
You are talking about the rigid metal pipe assembly and not a flexible hose, if I'm understanding correctly. That's what it looks like from your images and the part number that you posted. Do you have reason to believe the rigid pipe is compromised? Typically people just replace the flexible hoses, I believe, since the rubber degrades and can fail.
No I am talking about the hoses I will walk out to the car now and send a better photo. Just at work had some down time I circled both of the hoses they are connected to the heater hoses. I really appreciate the help. The rubber is burnt where the white stuff is. Since the parts are discontinues it looks like should I just go with aftermarket rubber hoses?
I suppose it's not impossible, but it seems very unlikely that the hard pipes have any issues. It looks to me like something is leaking above it and running down. The coolant used in our 100s dries up and crusts like that (easy to spot leaks)—in some of your other photos, you can see it crusting up at the tee joint also.
There's enough leakage there that I'd replace all of the soft lines, the clamps, and the tees themselves. Clean the crusties off the hard lines, and just keep an eye on it for the first week or two.
Got it, I don’t have a picture but it looks burnt and the lower part of that hose I circled is leaking. I will get pictures tonight and post
If it’s the pipe leaking (& not the rubber hose) and if the part is discontinued you have no choice…buy a used replacement from the junk yard, or here on MUD via the classifieds. Not a big deal.
Can someone also clarify I just ordered the clamps Toyota’s listing 96136-52101 as the clamps is that correct or is it ? Again thank you so much guys. Trying to get this done tommorow just don’t want to mess up.
• (8) Hose Clamps (96134-42100) (Horizontal hoses off Tee)
• (4) Hose Clamps (90467-19022) Vertical hoses off Tee)
Are those the right clamps it’s showing
96136-52101 just trying to get this done today at the shop. Thank you!
The latter two part numbers are what I used, and I know for sure they fit. The -52101 looks like the same kind of clamp, but I don't have a way to confirm it's correct.
To confirm, enter your VIN at partsouq.com and then browse through the diagrams. That'll make sure you get the correct parts for your model year.
Just checked partsouq.com it’s showing 96136-52101 for my vin # LC 2000. I’m confused. I’ve looking in the search filter but lots of miscommunication on which hose clamps I should use. Just trying to get this done today so I can drive my LC. Thank yoh
