My 1991 land cruiser has heat but is not super great. It takes it a while for the engine to heat up. hwy speeds and longer trips it works fine. but short 5 min drives not great. it does not smell like anti freeze in the cabin and the passenger floor is not wet like I have read about. seems like it takes a lot for the engine to get up to temp too. like it always stays in the bottom half of the temp gage. I had a 3rd gen 4runner and it heated up much quicker. am I being parinoid or is this just how this old vehicle operates?
Maybe thermostat is stuck half open. I’d replace that to start. Next on the list is flush the system to make sure the core isn’t clogged. Garden hose then flush with distilled water. Gallons to displace garden hose water and minerals associated with tap water.
My 91 was the same way. The previous owner replaced the radiator because it was clogged up, but he never swapped the heater core. I did not want to try and install a new heater core so I just flushed my heater core. I disconnected the heater hoses at the fire wall and ran water through the heater core with a garden hose. This flushed a bunch of crud out of the heater core and it helped to improve the heat. I did this using a simple low pressure chemical free flush to avoid causing a leak in the 29 year old heater core. I also replaced the heater valve on the firewall and made sure it was adjusted correctly. After all that my heat was much better, but it still seems to run a little cold. I have decided the reason is because of my aftermarket radiator and I think it cools better than the original radiator. I can take my rig ice fishing and leave at 5:00 am in 20f temps and my thermostat won't open on the interstate. I have had to start putting a piece of cardboard in front of the radiator for driving in these kinds of cold conditions otherwise the truck never gets to temp and the heater never gets got. Usually once the sun is out and the temps hit 30f than I don't need the cardboard anymore.
this makes me feel a lot better. Its good the truck does not get hot because its going to be blazing hot here in the summer with driving on the beach. Ill try to wash mine out the way you did. I think my radiator is a replacement one but its a toyota plastic one. these came with the brass ones I believe. I could be wrong on that.
Same, I'm replacing the thermostat and doing a flush. PO changed the radiator, but I don't think they bothered to do the thermostat, or they used an aftermarket one and it failed. If it still runs cold afterwards, I'm planning on the cardboard solution
I think I am going to pull out the old thermostat in the future. has anybody used the absolute wits end company? they have a good looking kit. all OEM for 75$ Complete Thermostat Kit for any 2F or 3F Engine
