Heater box question
MT PLEASANT SC
Just getting ready to reassemble my heater box with a sor rebuild kit and a new core. I just wanted to confirm a couple of things.
Do I glue the foam to the core with 3M77?
The sides will have double foam?
The bottom flap gets no foam?
The vent flap foam goes on the side facing the vent when in heat mode?
Thanks, Tommy
On a 76, top flapper door that blocks off plastic vent louvers has foam on both sides. Not sure why the backside needs foam, but mine has it. Lower flapper door that controls floor heat only has foam on top side.
Blower motor fresh air/cabin air door has foam on both sides.
You aren’t thinking about glueing foam to the heat exchanger fins are you?
What do you mean by sides will have double foam?
Here’s some pics.
Note the two foam resting pads for the upper door when it is in vent mode. They are 1.25” in length;)
Vent mode
Only edges of Heat exchanger has foam
Here’s some pics.
Vent modeView attachment 1605512
Only edges of Heat exchanger has foamView attachment 1605513
Here’s some pics.
Thanks, that is exactly what I needed. I wasn't going to cover the fins,just terminology on my part. I need to get another piece for the bottom flap.thanks, Tommy
@TOMMY76 @Nader
How thick is the flapper foam in the SOR kit?
Is any of it adhesive backed?
I have 3 heaters and 3 blowers I need to re-foam. I found some 1/8” thick sheets that have pressure senitive tape on the backside. I am thinking that and roll 1/2” thick firmer foam will work.:meh:
If you don't have the parts to look at and/or don't want to mess around trying to source the little pieces yourself, the SOR kit is still just barely worth it. VERY overpriced for what you get. There is absolutely nothing special about the foam or the hardware. I didn't have any of the hardware to work from, so I had to go with the SOR kit, but there are almost certainly better types of foam to use than the OEM open-celled foam and the cheap junk that comes in the SOR kit. Definitely room for improvement.
