The PO must have removed the plate off of the heat riser shaft - as it is no longer there. Which means that the hot exhaust gases are roasting my intake and carb. It appears as though SOR has a "block off gasket" that shields the intake from the exhaust. Once installed there will be no reason to have the useless shaft - plus I have an exhaust leak from the shaft bushings - anyone ever plug these up?? I guess I could have it welded over - or is there an easier way to plug these?
Shawn
Shawn
