Healdlight access
What year? The setup varies between the early FJ80s and later FZJ80s, IIRC... I could be wrong, though, the last time I looked under the hood of an FZJ was three weeks ago.
It shouldn't be that complicated. Even when I replaced my headlight assembly all I did was remove the corner light, then the grille, and then the bolts holding the light in place.
Took 10 minutes tops.
Just make sure you remove all the screws holding the grille in place.
[Edit]
Mine was for an FJ80 just incase there is any difference.
Removing the entire assembly isn't necessary. On the FJ80, the coolant tank conveniently slides out of its bracket, allowing access to the bulbs.
It can be done without removing them, however it is much easier to do with them out. Remove the corner light and there is a bolt behind it, remove the turn signal there is a bolt behind it, and of course remove the two bolts on the top. The grill has IIRC 4 bolts and one clip.
Thanks. I didn't realize the corner light came out. I didnt want to force anything, but it just popped right out. What happened was one of the lights went out and about a week later the othe one did. So I replaced the bulbs and they still dont work. Any thoughts? The highbeams both work. Im able to get a ride to and from work tomorrow, but if it isnt fixed by tuesday morning, ill have to take a day off work and take it in. At a loss for what to do. Please help.
Have you checked to see if the plugs have power? Its highly unlikely but possible that your new bulbs are broken.
Dunno if im really helping, just throwing out what I know.
