headliner ?
Anything can be done. The 93/94 uses a suspended type headliner with bows that provide the tension to the fabric. The 95+ have the fabric glued to a rigid substrate. IIRC all of the pillar trim pieces are different. I suppose you could make it work if you had the time and money to purchase all the pieces.
if anyone has a pic or description that would give me an idea how the later/one piece attaches to the roof--that would be kewl. Does this snap in similar to the cargo panels and door panels? ( i havent seen one of these and hard to visualize how its held up there and how much work it would take to retrofit vs. just reusing the bows of the older one ive got)
thanks for any replies
Why are you considering changing? I have thought about it because mine is filthy. I would like to see if anyone has had good luck with a cleaning solution to really spruce it up. When I was messing with mine, I came to the conclusion that getting an entire head liner up would require multiple people to get it just right.
i really want to pull out the sunroof and weld in metal panel to seal it up............i figured replacing the 94 headliner was a pita....and maybe this would be an easier option since its one piece.
I like that idea a lot. The sunroof seems like something that everyone wants, but I hate mine. It doesn't leak, but it rattles all the time. I hate that. It might be just as easy to weld it up and leave the sunroof visor in place.
id like the extra few inches of headroom by removing it. Also dropping 40lbs out of the highest point of the rig would be bad either since i think i open my sunroof once a year.
I did a seat/ height mod on mine and its nice to be up higher in the vehicle but im getting close to the headliner at 6'3 plus the seat/height addition.
The 95+ headliner is held in place by the grab handles, the sunroof trim thingy, the door trim things, and the hatch trim things. I'd pretty much bet it'd fit fine. But I hear they're pretty costly new.
