headlights
Grants Pass OR
I'm a new owner of a 72FJ. Headlights are not getting any juice. all other external lights work and all interior electronics are operational. When I pull the light switch out tot he 1st notch running lights including dash come on. 2nd notch everything shuts off. bad switch, bad ground, shorted switch???? Help me Mr. Wizard;)
Is it high and low beams that do not work or just the high or low beams. Add the selector switch into the mix if it is just one of them that works. Check the fuse, using a multimeter, too.
Oh... I forgot one thing. WELCOME to Mud!!! If you post a picture of your FJ40 please make sure the bezel is on right side up. The bezel police frown a lot on them being upside down.:bounce:
Try hitting the floor-mounted dimmer switch a few times. It can get caught in between, especially if it’s a 50 year old original part. ;)
