Headlights dimming at idle
Ogden, Utah
I have noticed that when I come to a stop light or sign, my headlights seem to dim down and when I go, the lights brighten. I have the alt. checked and voltage seems in the normal range at idle(according to the gauge) it is reading about 12 v and after stepping on the gas pedal it jumps to about 14 to 16 v. on the gauge. My battery is brand new. Any thoughts of what to check or what the problem is?:cheers:Woody
check the battery cables them selves. Try and get a view of the actual copper strands if you can. If they are green in color I'd replace them. Also clean all ground points to the engine and frame. You are having a voltage drop at the lights and it's probably from some resistance in the cables themselves or a dirty connection.
Thanks Rick, I just checked a few of the Grounds and the batt. cables and a couple showed some green color. I will clean and/or replace.
If you're over 100K and haven't changed the alternator brushes, you should consider changing them. It's easy (the FAQ has directions) and the parts are around $10, IIRC, from Cruiser Dan.
This is a great Idea. Seeing how many miles it has.(187,000) I was thinking about upgrading to a 130 or 150 amp alt. Thank you for the inputs good to go on. JW
This is normal...
At idle, if you turn the the heater fan on full you will see the voltage drop as well. Both of my 80s have done it, if it doesn't bug you too much, don't throw money at it..
in my opinion the voltage should be 13.8 - 14.2 volts at idle. is your idle too low?? this could cause low charge. it is also possible that the alternator belt is too loose. 12v is not recharging the battery, so if you had any reason to sit at idle for a long time at night in the rain using a winch your battery would definitely die. :o not a good situation. i still think something should be done about the low voltage at idle. good luck.
All great suggestions, I will look into this week on the days off.(all week, joys of FD life)I will post when I get some results. THANK YOU. JW
