Headlight trouble
Tucson, AZ
hello all.
I’m having some trouble with my headlights and such. When I got the truck my turn signals where intermittent, my dash lights where touchy, and my high beams come on when the lights are turned on, not my low beams.
I’ve got the turns to work 90% of the time by working the switch for a few minutes and the dash works and dims now as I also worked the light knob for a few minutes. After talking to @RAGINGMATT and consulting my users manual I concluded that the knob works properly. I think I’ve isolated it to the turn signal switch on the tree. In the manual I’m to click it forward to get high beams and be able to flick it back to flash highs. Right now it’s always high and if I flick it back I get lows as long as I hold it.
Questions:
Could the switch be broken internally?
How do I remove it?
What the heck is that green wire for?
Can you depin these connectors?
Any help is very appreciated!!
as far as the headlight switch goes :
- Green w/ red tracer stripe is B+ fused feed in from fuse box
- Solid Red is B+ Fused feed in from the fuse box Headlights
- Solid green out is Pull Switched B+ to : parking lights , interior illumination etc...
- Red w/ White stripe OUT is Pull Switched B+ to High Beam Dimmer Switch at steering column
- Red w / black stripe out B+ is simply for the interior illumination Dimmer rheostat circuit
you should find the Red wire w/ white stripe feeding terminal HD on your diagram
step # 1 check ALL your glass tube fuses for good measure using a illuminated test Light
I would simply check ALL your fuses right now for good measure , then u will know ..............
some times a glass tube fuse looks good , but in reality the foil element has either blown or become mechanically
disconnected from the inside end cap out of sight of the glass tube from vibration and or age & time ....
its happen to me many times
