headlight question
South west utah
I have a 91 fj80 and the headlights get brighter when I roll my drivers window up. Is this normal, if not what would cause this? Thanks
Brighter *while* they're going up, brighter once they're up, or both? (No idea in any case, but curious what you mean.)
Yes while going up or down, I noticed it two nights ago and was playing with it more tonight. They also get brighter when my turn signals flash on then dimmer when they flash off. Also they get brighter when I give it gas and my vents blow stronger when I give it gas. I know nothing of electrical systems but I have a feeling it's all related. Any ideas on what to start checking first.
Using an analog volt meter watch the needle when you use the power windows. Does voltage at the battery increase when you power a window? (engine running)
Try it key off engine off. Use the hazards to test for change in headlamp brightness.
Repeat the test with key on engine off.
Post results.
I'm thinking a diode in the rectifier or a cell in the battery.
Using a jumper wire connect one headlamp directly to the battery and compare to the other.
