I’ve read thru the posts regarding the headlights and combo switch, etc. I ended up replacing the combo switch, relay and repaired a broken wire to the license plate lights in the tailgate. There is power to the headlights.
The problem persists, whereas, when I just turn on the headlights all dash and indicator lights come on, as well as the fan motor, auto transmission temp indicator light, and when put into gear the horn also sounds! (relay makes noise when doing this)
The only thing that seems to work is the parking lights only. When I replaced the relay the lights and hi-beams came on for a minute, then again started symptoms above.
I’ve read that the relay can be reset by detaching the battery for 10 mins. The only thing I can think of to isolate the circuit is to pull all accessory fuses then see if condition is same or returns when I put each one back in. I’ve looked at the wiring diagram and checked every bulb and wire that I could find to no avail.
Has anyone ever seen this kind of thing? I’m stumped and about ready to take it to my mechanic. Thanks, and this is an awesome forum and I’ve been a proud FJ62 owner for about 8 months! Any clues will be greatly appreciated..
