Headlight plug adapter ID
Orange County, CA
I’m trying to identify the actual plug type/number for the low beam headlong connection. The male/female versions are in the photos.
I’m trying to order a wiring adapter to a 9006 connection for an LED driver.
You can cut those off if you want and just put in a 9005/6
The lx info is on here also.
I'm not home or I could send you an adapter to 9006 without cutting.
Thanks for the reply. I should have noted this is an LX. I'm attempting an LED conversion and was able to source adapters to go from spade to 9006 for the LED driver.
Now, there seems to be an issue with beam pattern that's highlighted by the LED 6000k temp.
There are errant squares of light at the top of the pattern. Although the cut off line is fairly clean, there are two areas above each hotspot that throw light way too high.
Interestingly, I re-installed the factory H1s and noticed the same issue, only muted by the warmer color temp.
I'm now on the hunt for pictures of other LX beam patterns to see if it's a defect or inherent.
Good times!
