Headlight issue
Southwestern CT
Did a search on headlights and didn't find anything regarding my situation.
Driving the other night and noticed the amount of light the truck was giving off suddenly dim. Checked the bulbs and the DS normal bulb was very dim. The DS Bright bulb was out completely. Changed them both and everything is the same: normal bulb dim, bright is out completely.
Any suggestions? No fuses are out.
There is a seperate fuse for each side. You may have a fuse that has developed high resistance but not completly failed. Try swapping the fuses to eliminate that.
Thanks for the suggestions. I didn't realize there was a separate fuse box under the hood :flipoff2: so.....
There was a 7.5 fuse in the slot (supposed to be 15). Guess someone was in a hurry. Replaced and all is well.
