Headlight Adjustment Screw Retainer
Anchorage, AK
Can someone give me a source/part # for these plastic retainers? Or an alternative?
Thanks,
Chris
Spector has an alternative, but definitely not OEM.
Part # 112-100A, description is "grommet ".
cool thanks - it says for 79 and later - I wonder if it can be made to fit early trucks too. I had to find a headlight screw at autozone that fit inside my headlight bucket with some trimming and I drilled out the inner hole and tapped it so the screw would work.
The exploded diagram shows 9/71 to 1984. Just used them on a '76 FJ40. They require a little trimming to fit, or the holes in the mounting bracket need to be opened up with a small square file.
I have 2 that are busted on a bib I just cleaned up for my truck. Was thinking that maybe a spring over the screw and a nyloc nut might do the trick. I haven't tried it yet but I think I could reach the nyloc with a wrench on the backside. I need to stop at the hardware store for some other nuts and bolts so I'll pick up some things to experiment with. The SOR ones seem like a cheap solution but I'd need to be ordering other stuff to make it worthwhile.
I welded stainless nuts in place of the inserts on mine , fixed permanently .
Sarge
OK, crazy question on this one. I'm trying to fix my busted headlight adjusters on our 77 FJ40, and my adjuster screws appear to be 1/4-28 (SAE fine pitch) threads. I thought they were a M6 fine pitch (.75) but i found a hardware store tonight with both and the M6 fine pitch definitely didn't fit.
am i dealing with a 'PO gone standard' thing here?
For my '73, it appears
Toyota Part No.: 90189-05013, NUT, HEADLAMP SELF LOCKING
Toyota Part No.: 81121-62010, SPRING, HEADLAMP TENSION
and the screw for the nut, with the collar,
Toyota Part No.: 81131-62010, SCREW, HEADLAMP ADJUSTING
may all be still available from Toyota.
@Iowa FJ40
I found out later that the "Toyota Part No.: 90189-05013, NUT, HEADLAMP SELF LOCKING" may be the square base one, that's shown "loose" in the picture above. For my '73, it was different.
What year is your truck? I may know of an alternative for replacing the round ones, if I can resurrect my memory banks. ;)
