Headgasket?
STL> MISSOURI
I have been reading about blown headgaskets, thread after thread! I checked to see if there were bubbles in the overflow and the answer was "NO". I do not believe I am using any
antifreeze, I looked under the oil fill cap and there is a small trace, mind you a small trace of milkshake. I looked on the dipstick and it was a litte white at the top. My rig runs a little
rough at start up, I smelled the exhaust and I do not think it is a problem. Are these telltale signs or what?
Thanx in advance for your expert advice.
george
Probably not, but post pics because it is impossible to tell from your verbal description. If you suspect something is amiss with your oil then contact Blackstone Labs and have them do a UOA.
A HG can leak coolant to combustion or coolant to oil or an external coolant leak. A visual inspection can find the external coolant leak(s). Be sure to inspect the rear of #6 with a mirror. The UOA can isolate the coolant to oil leak, and either bubbles in the coolant or a test of the coolant for combustion gases can find the remaining type of HG failure.
-B-
The moisture in the oil can simply be from not running the engine long enough to evaporate it out. If you only drive it for 5 mins from work and back home, moisture will build up inside the block. One of the easiest things to check is to pull the spark plugs and see if one looks quite different from the rest. After that, move on to a leak-down test. A rough idle and moisture in the oil can easily be two seperate problems.
I would not go so far to say that I just gave you "expert" advise. :hillbilly:
Thanks, I will check in the light tomorrow (plugs) and a good visual inspection. I did take a short trip an then checked the oil dipstick when I noticed the moisture. I then proceded to check the fill cap. I am taking a 30 minute drive now I will check then. I will post results tomorrow.
A few years ago I set my elderly aunt Mabel up with Internet. Mind you the woman had never been sick a day in her life. Well, in short order she discovered the WebMD website and shortly thereafter I was taking her to the doctor to make sure she didn't have a brain tumor. According to her, she had all the symptoms. Thank goodness she was fine. I never understood how a website could instill paranoia into someone so quickly unitl I found this one. Miss Kitty has 230,000 miles on her now. Original head gasket and Original PHH. I maintain the hell out of her and if the head gasket or the PHH fails I'll just pull over to the side of the road and call AAA and have them put her on a flatbed for a ride to my garage. Then I'll fix her. Until then I'm going to try really hard not to worry about it. Really hard....
Personally, with those two minor signs I'd send a sample off to Blackstone (or similar in your area). That condensation is from moisture from outside air, but if it's got a coolant component to it, they'll tell you even at the minutest levels. And I'd WANT to know that in advance, rather than possibly wrecking the engine or being on a trip with it.
DougM
First Toy, You nailed it! Paranoid!! I think I will send a sample to Blackstone, not just because I am paranoid! Doug I guess I will
postpone the headgasket video until later.
Thanks guys I should have put up a post before reading!!!
George:rolleyes:
...and if the head gasket or the PHH fails I'll just pull over to the side of the road and call AAA and have them put her on a flatbed for a ride to my garage.
This philosophy works if you stay on public roads and within 100 miles of your garage.
You'll think about this a lot more when your truck's primary purpose is expedition trips and day/weekend trips to remote areas where AAA cannot send a flatbed.
-B-
This was my plan too! But I didn't have to try not to worry about it. I just didn't worry about it. I was overly confident in HG reliability due to many years with an F, 3F,& 2F. I almost thought it would never happen to me. It's a good thing that my HG let go when I was only 15 miles from home, rather than the day before when I was 300+ miles from home in the Imperial Sand Dunes. That would have been way over the covered 100 miles.
Nope, I wouldn't think about it at all. If I were planning on heading out to a remote area, with 230,000 miles. I'd replace the PHH and PM the HG.
