Wanted Head light buckets
S.E. Tennessee
looking for a set of head light buckets #46 & #47. Need them cheap for a :princess: female cruiser:princess: friend.....she has a 78-fj40, thanks
"are they any different than earlier ones like say a 1970?"
$pecter says 1963 to 9-71 and 9-71 to 1984.
thanks for the reply
Jeff
if i have this right the early ones have the plug and wire built into them newer the plug from the harness plugs into the light bulb i think the hole is centered in the rear and big enough for the plug older plug wire goes through gromett hope im right and hope this helps good luck
Here a pic of both early and late
1963-9/71
9/71-1984
TTT
Found one complete assembly for 5 bucks......someone has to have one they don't want, it does not have to be perfect a little rust is ok , just not bent up. $50 is way too much for this chick......thanks
Back...... all the way to the top
Found what your looking for you cover shipping there yours. Will defenatley need to be cleaned up. were sprayed with undercoating
