Bodean
Hot Damn
Yeah, about 6-7 years ago. I did find the manifold. Has a broken bolt in it but could be extracted. Let me know
Bodean said:Yeah, about 6-7 years ago. I did find the manifold. Has a broken bolt in it but could be extracted. Let me know
Bodean said:Call Bob at TPI and he will steer you the right direction. We put 2 of the metal Toyota gaskets and some ultra high temp silicone on Tony's I think. I'll Have to check. No problems with that install. I think the header TPI sells is the same one as Mana-fre. Tell Bob you are from CLC. (I'm trying to get him to sive us something for the raffle).
Later,
handala said:whazaaaap...yankee foreigner boy here...
One thing from my limited experience with header I can say....the '40's come with bolts that you use to screw the headers into the engine block...it you switch those to the double sided bolts and then secure the header with a nut...it makes a much better seal...does that make sence?!
even i was able to get the header on with a single metal gasket, no sealant and had no leaks.
how dawg...I'm giving advice now!
handala said:how dawg...I'm giving advice now!
euclid said:
ps40-2 said:Thanks. I studied that thread some and have removed the pipe. It doens't say anything about the EGR cooler, located on the block.
Care to weld the pipe shut for me?
euclid said:sure. Can you take it off and bring it to me?
and donate to the Bodean Silver Star campaign.ps40-2 said:Don't forget to come by for aand donate to the Bodean Silver Star campaign.
