Head gasket
Texas
This is my first post. I have a 1997 LX450 and last week it started running rough then the check engine light came on (P0301). I smelt antifreeze and noticed white smoke from the exhaust. There were a lot bubbles in the radiator overflow tank so I got a combustion gas tester. The test showed exhaust gas in the radiator.
So, I've spent the last few days reading threads and watch YouTube videos on replacing the head gasket. It seems pretty straight forward so I'm going to replace it myself.
The one thing I am not sure of is who to send the head to. I'm in the DC/MD/VA area and am looking for recommendation on a machine shop to work/test the head.
I am trying to take the cams out but the hole to put the service bolt in the exhaust gear does not line up. Has this happen to any one before? Any recommendations?
1943877
Looks like the cams have been out before and someone skipped a step or, you have already pulled the timing chain gear from the other cam shaft. No big deal, it’s a booger to do,but, you can install the service bolt with the cam on a work bench later in the process. Or, you could attempt to align the holes and do it now. The world has not ended....
