Head gasket question
Cincinnati, OH
Head gasket had a pretty bad blowout, see pics. Looks like it had a small leak for a while. Question is, do you think a stock head gasket will seal over this pitting, or does block need decked?
There have been quite a few on here with a similar issue.
Do a search for "block pitting" or similar. Someone found a product that was able to be smeared (or sprayed?) over the deck for the new HG to seal on, but don't know if there are any long-term results.
If the bottom-end on these wasn't so robust, one would just pull it and rebuild it or go with factory new short block.
Thank you. Found a case that looked almost identical to mine.
