Head Gasket ok after all?
Fort Langley, BC
Posting this will surely cause it to fail.....
Back just before Christmas, I thought my head gasket was failing. Since last summer, I've basically tried to move the 80 to part-time duty by only using it for tasks that really require the size or capability of the 80 (not a daily driver anymore for the wife, she's got a G37X now :bounce:). The goal being to save the 80 for off-roading or hauling ect.. What this means is it that it sits for 2 or 3 weeks at a time.
Anyway during the cold snap here in BC in December, everytime I started it, the exhaust smelled super rich/sweet and there was a lot of "white smoke". I should comment that after running for 5 minutes, the exhaust seemed ok.
On the third event of this, I realized "it's the HG that's finally starting to fail!". I also then noticed a loss of coolant but hard to say over how long and I did see some bubbles in the overflow (could have been just from low coolant from another cause). anyway from then on, I stopped using it altogether, ordered the parts from Dan, ordered the DVD from Doug and started hunting for a good mechanic and also thinking about doing myself.
The one good thing out of this is that I did find a good Toyota tech (ex dealership with 20 years experience that I trust). He kindly agreed to watch the DVD and put up with my micro-mgt and overly concerned discussions about my cruiser. He spent a fair amount of time looking for HG failure:
  • check for coolant leak via pressure test
  • looking for bubbles
  • checked for exhaust gases in the coolant
  • checked the plugs for anything unusual
  • drove it and observed the exhaust
His feedback was that it looked good but perhaps it's on the edge of failing but no current signs of failure. He offered to replace as PM if I really wanted to but it was up to me.
My plan is to get the oil sample tested at Blackstone and drive it a bit more often and watch it like a hawk. Funny thing is that I was sort of glad it failed so that I could get this behind me.... but on the other hand, I'd like to avoid spending big bucks right now...
Perhaps I'll watch Doug's video a few more times, order some more parts that I overlooked and do this myself as PM. That partially depends on how busy I get doing other stuff.
I guess I'm posting this to:
a) cause it to promptly fail due to bad karma
b) seek advice from others on the investigation & possible remedy paths
BTW - Doug, great video. It gives me faith that I can do this.
Regards
All 80's I've been around have had their exhaust smell sweet. And it's pretty normal in cold weather for there to be lots of white "smoke" when the engine is cold.
Drive, and since you're all prepared for it plan on replacing the HG as PM. But do it on your time, don't feel rushed to do it.
sounds almost to the T exactly what im going through with mine. which mech did you take it to? id like to have his unofficial official certified master tech thoughts on my setup as well. ive got all the same symptoms as you, except no bubbles in the overflow. very rich/sweet smell, loss of coolant in overflow over period of time, but no visible leaks. oil stick & cap are clean runs fine & gets consistent avg mileage. i suspect coolant is getting burned out...hard to tell in this cool weather. i do have the 0401 code though...but i think thats the only thing keeping my HG from going. perhaps i'll send an oil sample to one of the diesel shops here.
"if it aint broke..dont fix it." helps me sleep at night. id also like to do this as PM, but id rather wait if/when she goes. i i just dont want to be 1000s of kms from home in the bush with the family if she does...
I'm glad I found this post...
Mine smokes like a train at start-up in cold weather. I was a little concerned that is was "too much" so I checked the overflow tank and all is well. Definitely more smoke than I am used to from a vehicle in cold weather. This is my first winter with the Cruiser. I believe "HG smoke" would linger more and not dissipate as quickly.
relief [rɪˈliːf]
n 1. a feeling of cheerfulness or optimism that follows the removal of anxiety, pain, or distress
Hi Riley,
I know exactly how you feel. Perched precariously on the fence! I take my yearly oil samples to the local Finning dealer; they're fast and reasonable. There is one near you on 92A in Langley. :popcorn:
Good luck, Greg
X2. Mine emits a fairly thick white cloud for the first few minutes, and I've always thought the exhaust smelled "nice". I would continue driving it as you wish, and check all the cooling system hoses and connections for little leaks (and continue being friends with this Toyota Tech, it could come in handy someday!). Does your heater core smell like coolant at all?
Two things...Get the Blackstone report (EASY) and get the compression checked. Mine is in the middle of a rebuild right now because of multiple problems. But the blackstone is cheap ( I think $20) and gives you exactly what you need to determine if you need a new HG.
I like the analogy "smokes like a train". I thought I had a blow HG cause mine blew so much smoke at start up. Got a compression and leak down, everything's perfect.
Define "loss of coolant in overflow over a period of time." Are you talking about losing enough that you need to refill it every oil change?
I've had to top off the :princess: truck once in the entire time we've owned it (almost 3 years now, 10k-12k miles a year). You will lose some coolant--it's half water, so dump hot water in a container vented to the atmosphere and some will evaporate--but it should be virtually nil. If you're adding a couple cups of water once a year (or three), that's probably fine. If you're adding a couple cups of water every oil change, you have a slow coolant leak somewhere that needs to be tracked down.
That does not mean it's a bad head gasket however. While your HG could have a slow leak in it and you're burning coolant, it's far more likely you have a leak somewhere (such as the PHH). I would clean up the engine (especially the underside) very carefully, then use a radiator pressure test (which pressurizes the whole system) to ramp up to operating pressure (don't overpressurize it). Check the hoses, connections, and radiator tanks carefully for leaks. Especially check the PHH as that's a common spot. I've also seen cases where the radiator tanks develop cracks due to age and stress, and can leak from there.
"If it ain't broke, don't fix it"
x2, if it's bad, it will be obvious soon enough.:meh: BTW, it's cold in Canuckistan, exhaust contains moisture, moisture condenses faster when it's cold. You're going to "smoke" a lot more in the winter.:idea:
well i put it to about half inch under the full line at a fillup, and next fillup, it was down some. probably about an inch or so above the low line. is that alot? ive replaced the PHH, and there looks to be old dried coolant on there, but that was most likely from a leak i had on the heater valve T fitting above the EGR. checked around best i could where most leaks would be on the head/block mating surface. seems clear on DS and nothing on the PS, near #6. of course i cant see the backside of the block. rad looks clear and under the cap i still see red coolant, nothing else. no rust flakes, no sludge..etc.
one thing i do notice from time to time is dried coolant whiteness along the black feeder & breather tube for the overflow. also, some crystalization of coolant around the overflow cap. is this indication of the coolant boiling over in the overflow res and steaming the tubes? cant figure out why it'd white out like that.
some things i still have to do aside from the oil test is check the plugs, and both compression and coolant pressure test. i think she's holding out for the better though. will probably have to monitor it more frequently come summertime.
You won't ever find a small/slow leak just by looking around. You have to very carefully clean the entire engine, then pressurize the system and carefully hunt for it.
If it's consistantly down (IE: down half an inch) every fillup (as opposed to down half an inch one fill up, back to normal the next, down the next, up the next...) then you're losing coolant somewhere, and far more than what could be attributed to normal evaporation.
If it's not leaving drops on the pavement I wouldn't worry too much about it. But it'd be better to track down where you are loosing coolant sooner rather than later.
If it's not getting any worse then that's a good indication that it's not the headgasket. From what I understand, the HG will just get progressively worse. I would keep a very close eye on it though.
I will be sending my oil out for analysis in the next couple of weeks.
Regarding coolant loss, it's hard for me to say how much I lost and over what timeframe since the truck hasn't been drive much since the summer time when I last flushed it. Perhaps I didn't recheck it that well after the last flush.
My main problem is that the cruiser is now relegated to "offroad and longer distance hauling" so my the law of averages, it won't fail close to home but out of town when I need it most.
I will start putting more miles on it in the short term just make sure it's really running just fine and not losing any coolant.
