HEAD GASKET ISSUES
Daly City, Ca
I just noticed that my oil is milky. I'm sure that my head gasket needs to be replaced. Can anyone tell me if Auto Zone is just has good has buying for a dealer. Also what other gaskets/ seals do I need to replace if Im replacing the Head Gasket? Any advice would be greatly appreciated.
You say you are sure but are you certain? Sounds likely but id do other tests before commiting to a hg job. Hydrocarbon test feom autozone. Bubble test. Etc.
Simple answer. No. The autozone one is about as good as your spellcheck ;)
Get oem gasket
Better yet get kit which will have most of what you will need. Read some HG threads, buy or download FSM, check the faq. Could purchase dvd but its not necessary with fsm.
Then there is the wants.... or the while you are in there items that can increase price but also increase reliability and confidence for years to come. Noone can tell you the cost here as everyones level of ocd varies.
Email/call and see if onur can get you a kit on the way. He can tell you what else you need
Welcome to LCPC
Thanks for the advice Jason. I'll definitely look into getting that test kit from Autozone. Btw who is onur? I'm new to the site.
Did mine about 3 months ago. Got my parts @beno. All OEM. He recommended the gasket kit which is as well worth it as it contained all the other gaskets for "while you are in there" seal replacement. I also got valve seals. I also got the water pump, hoses, and new OEM headgasket stuff. Had to get PS gasket from Mr. T. Also wrapped engine wire harness with heat resistant tape. Gasket kit came with injector seals. I also recommend replacing your vacuum hoses with silicone hoses while you have your intake out. I did a PHH bypass which is great.
I'll check out Beno as well. Thanks for all the info.
Sorry bout that. Yup, as mentioned they are one and the same..... and that is his contact info i provided you with the LCPC link.
While it may well be a HG I just wanted to encourage checking other potential points of contamination (oil cooler, cracked head, etc)
How does it run? any smoke from tailpipe? running hot or loosing coolant as well?
but if milky I would suggest not running it much beyond tests and necessary trips as coolant will eat up some rod bearings and make things worse
the hydrocarbon test....
http://www.autozone.com/loan-a-tools/block-tester/oem-block-tester/391378_0_0
basically rent the tool, buy the fluid, attach to radiator fill neck, fill with fluid, follow instructions which are basically run it up to a certain rpm for a set time and see if the fluid changes colors which would indicate combustion gases entering cooling system.
the bubble test....
Run the car up to ~3500 rpm and see if you see bubbles pushing up through your overflow tank off the rad. same concept.
quick and easy and perhaps not 100% reliable but good guide... id call it confirmed if you saw bubbles but id not be 100% safe feeling just from not witnessing.
lots of great info here..... LOTS . don't get overwhelmed but a good place to poke around for what others have learned.
80-series FAQ
and several good HG threads and while you are in there threads to look over to get an idea of scope of project.
this is for a 1996 which would apply to 93-97.... Look into adding some vehicle information to your signature in the profile section (upper right by search box) so we know which motor or variation you are working with
http://www.trollholescruisers.com/Tech/Manuals/Chassis and Body/1996 FZJ80 FSM.pdf
At minimum, you'll want to get the valve grind kit from the Toyota that includes most of the gaskets, seals and other items needed to do the HG. I would also have the head at least surfaced.
Here is a thread I started when I did mine. I ended up going pretty much all out on the top end of the motor and everything that came off. I didn't end up getting to the crank shaft seal though as I had more than enough to keep me busy. That project still needs to get done at some point.
Head Gasket Checklist, things to consider replacing as long as I am in there.
If @beno is up and running after his move, I would contact him and let him know what you are up against. He has good prices and a ton of knowledge.
the bubble test....
80-series FAQ
I was able to get a hold of Beno. Thanks for the referral.
My 91 Landcruiser runs good considering whats going on. There's no white smoke. It doesn't over heat but I my coolant reservoir is always empty. Would you know anyone who has a FSM for a 91?
Not exactly fsm but look at the offerings by Marshall. Has an engine repair manual and chasis and body fsm. Might get you by but i did not download and look through. Also maybe @jonheld can link you his website that has been instrumental for many 3fe owners.
For Sale - 40, 50, 60, and 80 series FSM for a hell of a price.
