Head Gasket Help
Corbin, did you see post #11?
Check those things and then post.
as per your post #11, it is not a constant miss.
i just drove it for a little while and still no CEL. I have been running with the AC off, and when i turned it on for the test drive, it shoots the rpm up to about 850-900 rpms as it always has, and the miss went away. as soon as the compressor turns off, the miss came back.
now i got something,
threw codes p0000 p0304 p0305 p0306
How was the engine power output? That's a whole bunch of mis-fire codes, dang!
it actually ran good, not even noticable above 1k rpms when i took off
later today i am going to pull the throttle body again and recheck each injector and put some dielectric grease on each connector
the scangauge timing has really nothing to do the actual timing, at least that's what I found out. See if you can borrow/rent a timing light and at least get that dialed in and eliminate that possibility. Another easy thing to do is make sure that the offending cylinder spark plugs are firing. Maybe rent a spark plug firing indicator of some sort and see if you're getting a consistent spark to the offending cylinders.
So finally got some time after work to check timing and it was WAY off, runs like a top now. Smoking is slowy disapearing, went for a long drive and is almost gone.
so glad this is over with and replaced a lot of PM items, i should have a good running vehicle for another 150k miles... knock on wood
Great news!
It gives a nice feeling of satisfaction to be able to do a major engine repair like that and have it all come out well, doesn't it. And think of all the $$$ you saved as well.
Glad it turned out to be a simple adjustment.
Congratulations!
:D
Nice job, job well done.
