Swapping a 2F into my 40. I'm keeping everything but the engine itself as is for a 40 with an F originally ie. the alternator on the driver side, orange metal fan, F bellhousing (driver side slave cylinder) etc. I also want to use the F air cleaner. Problem is that it mounts with two of the head bolts. #1 and #5 (loosen sequence). If I take these loose to position the air cleaner and then re-torque them will I screw up the head or the gasket or both?
thanks
Chris
thanks
Chris
