Head bolts
What are people's thoughts on Beck Arnley head bolts? I would prefer OEM, but mechanic couldn't source them in time and couldn't source ARP in time either.
Did a search but not much info out there on them. Thanks.
i checked all of mine and had 1 out of spec got a oem replacement and reused the rest all good for over 50,000 miles so far just reuse em I done my rebuild at 324,000 and now going on 381,000 miles
Not sure what the old ones looked like, but apparently the HG was replaced at some point by PO. The person who did that job didn't have washers installed with the head bolts so torque was out of spec which is speculation on why the HG failed. I am guessing the bolts are not oem and since the washers were missing it makes sense to just replace since it is hard to know how much torque they were torqued to.
Not sure why the dealer is having a hard time getting OEM headbolts. They were stating it would be several days to get them in.
I got several OEM new ones and all of my old ones. I can get them to you by Thursday-Friday. You pay shipping.
Thanks for the offer. I have to be back on the road by Thursday unfortunately.
Your Toyota mechanic should be able to source them on 1 day from any California warehouse.
I hope that is the case, for some reason I was being told it would take several days to source them.
From what I have seen from beck arnley they just rebrand parts. For example tie rods that are beck arnley are stamped 555.
So it is impossible to tell what you are getting until they arrive and inspect the bolts? I would be hard to get reliable reviews as well if people are receiving different rebranded bolts unless they just rebrand from the same source? I thought I saw a post on here somewhere that said the beck arnley bolts they recieved were made in China and the quality was suspect so they returned them. Don't know if they were suspect just because they were made in China or if the bolts themselves had manufacturing defects.
Hard to imagine that Toyota USA is out of head bolts. You could just get a set of Arp bolts. Jeggs, or Summit, maybe even Amazon or Rock Auto should be able to expedite shipping.
I haven't looked myself, but they said the ARP's were back ordered. I don't think Toyota is out of bolts but was told delivery time was going to be several days.
Yea it would be impossible. And to be honest if you had a Toyota bolt next to a beck bolt you may not be able to tell a difference.
I was told the beck arnley part number was the same part number as the toyota OEM bolts. Don't know if that is just a smart marketing move by beck arnley to have their bolts show up in a search using OEM part numbers or if they are the same bolts as OEM?
Lots of these companies have next day delivery. Amazon has same day on lots of stuff.
Haven't seen the BECK/ARNLEY bolts, so no help there. The part number is 0161024, so not the same. They do reference the factory number, good marketing, but also handy for confirming that it is the correct part.
I always replace all head bolts as I do rod ends, not worth the hassle if one does not pull down right.
If replacing a set then trying to match one brand with another is not an issue.
Regards
Dave
@cahill How did this turn out? I was at one of the places that The dealer called and I was offering to pull used bolts if it would help out. One must assume it got resolved since your last update was five days ago.
Hope everything worked out.
They sourced some aftermarket bolts and were able to button it all back up. Drove it home on Thursday without any trouble. Hoping this will be the last of it for a while :) Thanks for being willing to help out.
