HDJ81VX LTD Console Freezer/Fridge problem?
Laurentians North of Montreal, QC
Hey Folks,
Just noticed today that the frezzer/fridge blows hot air instead of cold. I had the front and rear heater on as it was a fairly cold day.
Is this normal or is something amiss? Any way to diagnose it? I suppose it functions on the Peltier effect?
Any advice is, as usual, most welcome!
Chris
Console fridge
It functions as a circuit off the main aircon. I have one and have had lots of problems with the whole system.
Had the system regassed and leak tested several times. Had the compressor rebuilt and then refitted and regassed. Things are Ok for a while and then no coolbox and no cool vehicle.
Interested to see how yours turns out
Cheers
Thanks for the info! Then if I undesrtand correctly, if you are heating your car, the cooler cannot possibly work... Am I correct? If so I'm going to have to wait to get the truck in a warm garage before I test this...
Cheers
I empathize about your air conditionning problems. I had a problem on a Volvo that was very difficult to repair (had to remove the whole dash to access a vaccum switching controller), hope Toyota has a smarter and sturdier design...
Thanks for your input!
Chris
I've kept an undisclosed number of canned bevies ice cold in mine last weekend with the heater on full at times - does yours not have separate temp. buttons? off/colc/ice
curious
This is a pre-cursor to catastrophic engine failure. After the console fridge goes south, the entire vehicle starts to disintegrate. I think you better sell it to me before it self-destructs. :D
No you can still use the heater and have cold beer. The circuit for the cooler has some sort of valve that allows it to cool while the heater is heating. Also you can have heat while the Aircon is on. This is the best way to lower the humidity in the vehicle. Working in Antarctica at the moment but I am going to take the truck back in when I get home and see if we can't get to the bottom of the problem.
Do you have the ice trays for your fridge?
curious
Yes it does have these buttons. I have since noticed that when I put the A/C on the compressor clutch doesn't engage at all, presumably because the system is empty.
What kind of refrigerant does it take? I can get some when I go to the States for Thanksgiving.
It's definitely the aircon that doesn't work. Must look into it further, but I presume, since the clutch is not engaging, that it is empty. What type of refrigerant does it take? I could buy some in the US (unfortunately refrigerant can't be bought in stores in Canada)
I do have the ice trays and the cold pack for the freezer. Very neat, if it works!
Thanks for your input, looking forward to some more :)
Chris
A freezer fridge... in the console... What???
For those of us in North America who weren't given many options... Could you post a couple of pictures of this console fridge/freezer for us to drool over?
Here ya go :)
First picture: The console itself. Notice how clean the nice suede seats are, not bad for 15 years :)
Second picture: Enlargement detail of the Off/Ice/Cool buttons (with leds that light up when it's running)
Third picture: Inside of the console, which is made of insulated material with a hermetically sealing top door. . Cooling vent outlet at top and two ice cube trays partially taken out just below (picture taken with sliding door removed). Pardon the dirtiness, I havent cleaned it yet. Plus I still need to see whether there is actually anything to drool about (still need to fix the A/C first).
:eek: :eek: :eek: :eek: :eek:
First I noticed that you have a "RHD", so the useless "Cup holder" is on the right hand of the center console....
Second, I notice that I can't stand just yet because of how fricken awesome that is!
Third, I noticed there are some buttons just in front of the LED buttons you highlighted....sir, what do those do?
wow...just wow....
First I noticed that you have a "RHD", so the useless "Cup holder" is on the right hand of the center console.....
Actually, although squarish and a bit shallow, a standard fast food cup fits perfectly in there...
Wait till you see how it looks from outside, from inside, under the hood and from underneath! (coming up in a separate post)
wow...just wow....
Two dual heat level seat warmers... That actually work very well :)
Hijack! We are parting out a rolled HDJ81 that has the center console fridge if anyone wants to add one to their FZJ. Also have a HDJ81 half cut with the cooler. Both are grey interiors
Sheldon
Sheldon
How about including a link to additional information in this hijack?
