HDJ81 tech
Abbotsford B.C. Canada
I'm looking at an HDJ81, and it looks great except it seems to have a rough cold start as well as it seems to get less economy than the other 81's I've looked at. Any suggestions as to what it might be?
Thanx
Thanx
It could be the glow plugs,injectors or pump.A worse case scenario would be bad compression.
The colour of the smoke is an indicator.
If it runs on 4-5 cylinders for some time ,then it could be expensive.
At which temp are you stating .. ?
Me at 24 - 28 C have no problems and the glow plugs are not necesary .. clean start .. you should start with your injectors ..
