HDJ81 Not Shifting Into Reverse (Automatic)
Christina Lake, BC
My vehicle does not want to drop into reverse. After warming up, driving to town (15 mins @ 90 km/h) and driving around town, parking, backing up etc I will park for a few minutes with the vehicle idling and go to back up and the tranny does not want to drop into reverse. It shifts from P to N to D 2 L without hesitation put not R. If I shut her off and start her right back up problem solved. Stock gauges with everything reading normal. I have not found anything in the forums, online manuals or Max Ellery so I am looking to the guru's for guidance. This has happened 3 times in the last 2 months and I am getting worried. :confused:
Cheers, Sheldon
just check the links ajustment at the tranny .. after that, tranny fluid replace ( keep the old one ) ..
if not .. you don't want to read what I have to say ..
Okay so it happened again this afternoon, shift from Park to Reverse, nothing, Park to Drive etc tranny engages. To fix the problem I shut off the cruiser and start it back up, problem solved. I was thinking something electrical but I will have a look at the linkage adjustment.
Tapage - So can you give me a worst case scenario?
First I need to ask if it only occurs when the tranny it's cold . .?
Are the backup lights (and beaper if you have one) kicking on at any point in the shifter's throw...specifically when the shifter is pushed ahead of R or pulled back from R. If both the lights and reverse gear fail at the same time, look at linkage adjustment, neutral safety switch, transmission solenoids. I've heard that a faulty switch can result in odd tranny behaviour. I rebuilt my NSS last year and they're not that tough but my symptoms were only light and beaper related...actual reverse gear still worked. Search neutral safety switch, transmission solenoid, transmission ECU
Also the next time reverse fails you could try throwing it in drive and monitor the shift from 2nd to 3rd. Read this first (specifically how reverse gear is engaged by the same clutch pack as 3rd gear) and you'll see where this is going. Personally I can't see this being the case though....shutting the truck down and restarting should have no effect if it were.
https://forum.ih8mud.com/80-series-tech/65907-tranny-rebuild-shadetree-mechanic-style.html
You think the neutral safety switch it's related in this behivor .. ?
Maybe solenoids .. that are electrical related .. other chance.
Tapage & TwoThirtyDirty,
I have not had it occur when the tranny is cold. It always happens when the vehicle is warmed up. The backup beeper (annoying, yet good cause I have little kids) does engage, I will check with Reverse lights next time. My mechanic (not versed in Yota's) seems to think electrical problem because a shut-off and startup resets it everytime (so far, knock, knock).
I will do some more searching on solenoids.
Did more checking and I think you have the A442F which is electronically controlled...solenoids accesible via the transmission pan. If this is the case (should say on the driver's side door jamb I think) then you should be able to pull a code to find out what's up. Don't know how to do this myself but you can consult the FSM or the manuals sticky at the top of the diesel forum or maybe this will help
https://forum.ih8mud.com/80-series-tech/186148-1994-fzj80-transmission-problem.html
The access to the solenoids vía oil pan are not that hard .. but I don't find anything else to do, more than clean and reinstall 'em ..
