HDJ81 IP Question
Sonofaskipper
Southern Oregon
Hey all,
I’m planning on removing the injectors and IP and sending them off to DFIS in Portland for a rebuild. Once the rebuild is complete, will I have to time the pump? If so, will I need the factory service tool? Thanks in advance! I’m out at sea, with limited internet access.
Ryland
They rebuilt my injectors last month, for mine! They are by far one of the nicest shops I've ever had to deal with. My next step is also doing timing on my pump, i'll update in my thread when it happens and hopefully it'l help you, too!
Since all your injector lines would be pulled, you will have lots of room to work. I have read other posts about people having success with a dial indicator mounted on a magnetic base to the oil filter. Then, use extensions on the indicator pin to get in and measure plunger depth, then follow fsm I have never seen a photo of this method in use, however.
I don't have and HDJ81, but...
Another bump for DFIS in Oregon. they did my IP and injectors. They were honest with me. They said if they could clean my injectors they would, if not they could get new nozzles. This would have been a prime opportunity for someone to make some cash. They called and said they were able to clean them and they checked out great, no need to spend extra money. Great shop and communication.
Dirty old pump came back like this. I haven't got to run it yet, but impressed with the shop so far.
Denco Diesel has a good video for timing the pump. I have the factory Toyota tool if you need to use it. I can lend it with a deposit. You would need a dial indicator for the tool though.
@Sonofaskipper, I have both the Denso timing tool and the correct dial indicator also. To get the timing right you MUST use the tool because as others have stated, a tiny bit of movement on the pump is quite a bit of timing.
Thanks all for the input. Unfortunately, I had to take a 2 week class in my off time last month, so I didn’t get around to pulling the pump. I did order a VE pump timing kit though.
