Hdj81 fusible link blows instantly
montreal canada
hey guys
I keep blowing the black fusible link evrytime I try to crank..
Everything else seems to be working fine..
Any ideas?
Thanks
Better trace the wiring!
You must be shorting to ground. If possible undo any sketchy wiring you or the PO attempted.
For short term testing use a self reset type breaker or an inline fuse rather than blowing fusible links.
From memory that wire goes under the wiper fluid container.
Personally, I'd probably have the starter tested first.
Its easy enough to do. Take it to a good remanufacturing shop, and see what they find.
