The thing you have to remember is that there USUALLY are no big leaks. A/C units don't leak that way. Normally the coolant escapes due to the expanding and contracting of the seals due to the temperature differences they are subjected to. Most people think that if their a/c systems suddenly don't blow cold at all, it's because one day there was a big leak, but that's in most cases not true... it's b/c the cooling system is no longer effective at all if there is less than a certain amount of coolant in it. If it makes you feel better, get it evacuated and rebuilt, or retrofitted, but most retrofitted and rebuilt a/c systems only last no more than a few years anyway before they need to be fixed again. Personally, if I recharge it once a year, it's still cheaper doing this 5 times than having it serviced, and hoping it'll last that same length of time, plus in most cases it wont blow as cold.
Don't forget, you only need 1 bottle for a recharge, and the kit contains 2 bottles, so it's really quite a deal when you consider the cost. $35 per application.
