Hdj81 brake options
I tried aftermarket brake pads and rotors in my truck and wasn't happy with them so went back to OEM.
Brad
No work my friend.
93 up 80 series calipers and rotors are bigger.
So what do we do to upgrade the brakes on the early ('90-93) '81s? Mine are decidedly un-impressive and I am facing new rear rotors/calipers soon. Suspect the fronts are more critical to good braking...
I put no-name rotors and 100 series pads on the front a while back. It took the braking from unimpressive to slightly less-unimpressive. You have to trim the 100 series pads to fit in the calipers, but I just traced the profile of the old pad on the new one and took a grinder to it. Wearing a resiprator is a must for this!
Going with genuine Toyota 80 pads and rotors would probably net you just as good results, with less hassle. I wondered if the improvement with my truck was just by virtue of having new brakes, not necessarily better brakes...
Did that ramble actually help?
No work my friend.
So would it be possible to put the newer large brake assemblies on the older 80 series?
Theoretically you should be able to swap bigger brakes on from a 93 up 80 series.
Not sure how many of the parts you would have to change. Hopefully not the Knuckle assy.
Thinking Rotors, calipers, backing plates for sure.
Spend some time on Toyodiy.com (if you don't have access to Toyota EPC) and look at the part number to model year spans on the various parts.
15" rims may have clearance issues.
It can be done. I did it about 8 years ago on my first 80.
You need rotors calipers and the backing plates.
:beer:,
LandCrusher
I don't know what size brakes come on the JDM 81 series, but on USA-market FJ80 trucks, vintage 1991-1992, the rotors/calipers are smaller than the 93-97 trucks.
It's a common upgrade on the older trucks to swap in the larger 93-97 rotors/calipers. Yes, they do provide a greater braking force. You can also fit 100 series pads into those larger calipers for even greater braking enhancement.
I've done both, along with teflon/steel-braided soft lines, and high-end aftermarket rotors and pads, and the truck stops quite well now. It was pretty bad before.
Dana
One of the guys in our club just tried to upgrade the rear of his HDJ81 to the US-spec rear brakes. Calipers appeared to be identical. Of course the rotors are too big. and the backing plates were too small. Options are grinding the lip off the backing plates or sourcing used ones. Toyota Canada's list price on the backing plates was $800/ea!!!!!!
So I went to ATEB for new back brakes as they were squealing. Phillip pulled the tires off and right away I knew he wasn't happy. He ripped into the front hub and the outer bearing came out in bits! Guess that was the faint grumble I noticed! Running his hands over the rotors (15,ooo km on them) he asks if there is pulsation. I say 'well yes, and the brakes are also particularly s***ty, sir'. Hmm he says. 'How about we do a little upgrading? ' So off come the front rotors and calipers and on go the LX450 rotors and calipers and the Black Hawk pads. Phillip used his plasma cutter to knock off the flanges on the front dust shields. The LX rotors are waaaay bigger and far thicker than the stockers. Had the rear rotors turned, pads were ok and he tuned up my parking brake. New bearings and grease both sides. I took the boys out for lunch and we discussed my truck and other issues I was having (overheat on the highway, weak A/C, etc.) BAck at ATEB, Phillip flushed my brake fluid and took her for a spin. I can now lock my front brakes and the truck stops like a modern car! Awesome. But I wasn't done yet. John and Phillip removed my fan and clutch, cleaned it and filled it with Toyota silicone oil. It was dry and not spinning the fan. Then they took off the grille and rad supports and cleaned out my radiators fins, condenser and tranny cooler too. My overheat is gone and my AC blows cold! Seems the mud that got everywhere in my famous back yard wheeling incident had plugged my Rad, infiltrated my wheel bearing etc. Those two guys worked on my truck from 9 am to 5 pm with a lunch break and gave me a lesson in making BioDiesel. They also tolerated me looking over their shoulders all day and asking stupid questions. With my 16 inch stock wheels the new LX 450 units bolted right up and the difference is truly remarkable. All you have to do is cut the flanges off the dust shields. All the parts and 2 guys for 6 hours. Any guesses what the bill was?
