HDJ81 / ARB Locker - realtime help!!
Calgary, AB.
Hi guys, bought locally new f & r ARBs for my 1990 HDJ81... parts I received are RD132 front and RD153 rear. Also received install kits (8" front and 8.9" rear) from Nitro Gear for each. I've got the knuckles all cleaned up and ready to reassemble so next is the third member. Pulled out and all cleaned up... backlash check, all is good ... Problem is, I popped off the carrier bearing caps, and just for kicks held one of the old races up to the new ones in the install kit... old ones are bigger. It appears I have received the 45mm ID bearings as opposed to the ones I pulled, which are larger at 50mm. s***! Of course I don't want to reuse my old ones and damage them when I pull them off the diff... maybe I'm screwed?
Then I start taking measurements in relation to old diff and ARB RD132... seeing if reusing the old 50mm larger bearings for the time being to not have the truck down is even an option. I check the size and thread of the adjusters, I realized the ARB comes with two carrier bearing adjusters, one smaller and one larger ( for the 50mm bearings ) and you only need one - as one side gets old one reused and the other gets the ARB toothed adjuster. So the ARB larger adjuster fits where it needs to in the housing, cool Then after some measuring from old diff to the ARB it appears even if I reuse my old bearings, when I would bolt up the ring gear to the locker that the locker would put the ring gear closer to the pinion... like 1/4"????? The dimensions from the outer edge of the splined side shafts are different from my old diff to the ARB
SO... I'm questioning is this the right locker for my diff? Yet I'm sure it is as it's been ordered specifically by a gear specialty shop that requested my year make model and VIN...
Obviously the trucks torn apart for the night and I'm assuming they are closed for the weekend... even if they were open it took me a LONG time to get these parts, even these install kits ( which I'm assuming the front is wrong maybe the rear is too? ) took me like a month til they said they arrived.
Can anyone chime in if you've installed ARBs in an HDJ81 ??? I am mechanically inclined, with all necessary tools, but must admit I've never set up a diff, let alone an ARB... IS THERE SOMETHING IM MISSING HERE?????
ANY ADVICE WOULD MEAN SOOOOO MUCH!!!!!
bump!
The RD132 8'' high Pinion has the larger carrier bearings. In the states gassers have a RD142 9.5 rear which have the smaller carrier bearings. 8 Inch Pinion bearings are much beefier than the rear as well. Look and see If the kits carrier bearings were mixed up. Unless I misseed It I did not read where you looked at the RD153 Kit . I have not built a RD153 In a 8.9 so I can't say for sure. Good Luck..!
ok, now I understand the side collar on the locker is a bit longer to apply the air collar, and that the axle housing may need to be grounded to slide it in...
so I am thinking I'll be fine, but looks like the same beating as the original is what is needed?
OE = Koyo TR100802-2-N ???
I realize that this is a 4 year old thread, but I have just experienced the same issue. My 1991 HDJ81 has a high pinion front differential with the 83mm outer diameter. Apparently the North American version uses an 80mm journal. The bearing dimensions needed for my application are 50mm ID, 15.5mm width, and 83mm OD. The KOYO TR100802-2 bearing meets the spec.
The only place that I can find that carries this bearing is 123bearing.com (2 bearings for $105 shipped). I love my LC, but Sometimes these non-North American spec vehicles are a pain in the posterior anatomy...
You can buy the correct OEM part from your Toyota parts dept.
We definitely have the correct carrier bearings @ Cruiser Outfitters. Give us a shout if we can help! 801-563-1277
I wish that I had posted up before pulling the trigger on the $105 bearings. I'm not accustomed to having a supportive community... I will be certain to check with Cruiser Outfitters on my next projects.
