Wanted Hdj81/80 throttle cable
Everett, WA
Really looking for an hdj81/hdj80, rhd 1hdt (1hz may work?) accelerator cable. Not the trans kick down cable. I ordered one from Japan only for them to cancel since it's out of production. Mines about to fail.
do you need the cable from the throttle pedal to the cruise actuator, or from the cruise actuator to the injection pump?
Oh good point, I don't have cruise - pedal to the injection pump
You can try to source 78180-60321 which most likely will work.
I would contact Dave Stedman in Japan for this one. Japan4x4 Export Service
This is the part number i ordered from Amayama (accepted then cancelled since its out of production and stock). I'll ask him thanks!
While we're on the topic of cable interchangeability, do you know by any chance what other non-discontinued cables might work for a LHD HDJ80 (pedal to cruise actuator)? Both correct LHD HDJ80 cable, as well as FJ80 cable that is also long enough are discontinued with ZERO stock left anywhere in the world (i checked).
If anyone else is in a similar pickle: an fj80 throttle cable works. Had to enlarge the 2 mounting guide holes and it is a little longer, but connects just fine
