hdj100 rear diff locker
Belgium
Hi,
A question: my mechanic warned me not to use the rear diff lock as they're known to get stuck and block you from using the car and repairing/replacing is a big problem on these. Is this correct? Is there a way to verify if it is still operable without getting stuck?
Is it absolutely sure that they fail in the open position. My mechanic seems to suggest otherwise.
Worst case, remove the actuator and slide the sleeve back to free the axles. Then figure out if the actuator 'actuates' or not. You might jack up one side and rotate the wheel back and forth while you disengage the locker a few times, to see if that frees it.
From here.
