xeuxaz
- Thread starter
- #21
Old screws came out with no fight at all, using the JIS bit. Fit like a glove, having the right tools really does make a difference. Added a little purple Loctite to each on reinstall and cleaned up the surrounding area while I was in there. Also, shoutout to the Cruiser Patch fan wrench tool.Looks like you got the oil pump cover O-ring installed, any trouble with that?
Is that an OEM harmonic balancer?
And yes, OEM harmonic balancer from Bell Lexus.
While everything was apart, I did a test fit of the 150A alternator with the Landtank bracket, and it dropped right in. Also swapped the idler pulley. Debating swapping the A/C clutch assembly while it's all this accessible to freshen it up.
Completed so far:
- 13470-66030 HB / Crank pulley
- 90311-52022 front crank seal
- 15188-66020 Oil pump cover O-ring
- 15183-66020 Oil pump cover screws
- 90099-14118 Distributor O-ring
- 16100-69325 Aisin water pump
- 90916-03117 thermostat + 16346-66020 gasket
- 90916-02353-83 Belts
- 16603-66010 alternator idler pulley
- Land tank alternator upgrade kit
