OK... After searching for hours, I have come up with nothing that helps.. I have a 1974 FJ55 that we are trying to put 33x12.50 Super Swamper Thornbirds on. The rims are 15" tall, 9" wide, with 3.75" of BS, and a 1/4" spacer.. The cruiser has a 3" lift... The tires fit fine. until you turn the wheel all the way to the right, and the lugs on the tires hit the draglink where it connects to the center arm... No problem turningleft.. If we had a saginaw power steering conversion, this wouldnt be an issue... On top of it, I spent all day going from tire store to tire store looking for a set of rims with less of an offset, and found absolutely nothing. Everyone I talked to, said I should buy a 1" wheel adpater/spacer.. I'm not real sold on the adapter, as I read they add alot more stress to your knuckles and wheel bearings.. Any advice or comments would be awesome...
