Hause or Roller?
S. Jersey - New Germany
I just put a Slee Short Bus bumper on my truck and I am looking for a winch. I don't think that I will be using the winch all that much but I still want one for any emergencies. In making a decision I am not sure to go with a hause or rooler fairlead. I think for what I need the winch for I can get away with the hause fairlead. Any thoughts?
Good point, I'll call Christo tomorrow.
Personal preference, I would modify the bumper to accept a roller fairlead, or buy one that accepts one already. But, if you're going to go with a hause, get one that is of material that is as hard, or harder than, the rope you're going to use. Aluminum is softer than steel, but it is also more abrasive. You wear through more cutting tools on aluminum than on steel. Just my $0.02.:meh:
If you are running synthetic rope on winch, you'll need the hawse fairlead. Wire rope you have the option with the roller being superior for pulls that are not directly lined up. Synthetic rope seems to suffer damage if it binds in corners of a roller fairlead.
Hause - I am not sure if the Short Bus is designed for a roller fairlead...
- Mark
Called Slee today and the Short Bus does take a roller fairlead. The roller fairlead would stick out pretty far detracting from the bumper's design.
I run a steel hawse on my Shortbus since I run wire winch cable. The roller just stuck out to far, plus it looked like s**t.:D
What model Warn winch do you have and where did you get your fairlead?
I run a Warn M8000 and I bought the steel hawse online. My winch is also only for emergencies.
Where did you get your fairlead?
