has anyone installed a later model column?
Max man..
What are you trying to gain?
Are you trying to do a "bolt in" power stock steering swap?
You will need to modify your firewall where the old column passes through, cutting a larger hole in it to accept the different mounting set up that the later column uses....and make the associated wiring changes for the turn signal and horn...and the high-low beam if you so desire.
noooo my steering was TERRIBLE. you would just hit one small dip in the road and you would just lose control. there was so much play in my old column, and centerlink. so i picked up ians old steering setup and one of wes's columns he had for sale. i really just dont have the cash to do power steering right now...
74fj40 said:
you would just hit one small dip in the road and you would just lose control...
You have a lift kit in this truck, correct?
Are you running longer shackles up front also?
What is your castor angle currently?
If this is not in spec, or your trunion/knuckle bearings are shot, it does not matter what kind of steering system you have, it will not improve anything...and could only mask the real issue in play.
Your 72 should have the better bellcrank assembly up front...the same one that was used until the end of the production run on the 40 series....this is very durable and easily adjusted and rebuildable.
74fj40 said:
thick part is towards the back. im 100% sure thats how it should be...
Sure? Did you say sure?
:grinpimp:
Poser said:
Max man..
Poser,
The information you provided is not entirely correct. One can sucessfully mount a new steering column through existing firewall without any cutting. BTB makes a very nice column mount plate that bolts into the stock bolt holes. One can either mount a 2" or 2 1/4" steering column. I elected to go with the 2" with a tilt wheel.
If you do the mod, you'll have to replace the steering rod (from the column to the steering box). BTB makes a very nice telescoping rod that can be adjusted to fit into existing steering parts. In all honestly the total application produces a nice and good working finished product.
Later
UNO.
1973Guppie said:
yeah, or you could do the swap as poser indicates, save a boatload of $ and pay off your mortgage.
Actually its not that expensive to do the swap. The most expensive part is the steering column which is about $350.00 out of summit. Total swap expense is about $750.00, not all that much considering what you get.
74fj40 said:
woah woah woah.
this doesnt make sense to me...
stock pinion is something like +1 (actually pointing down)
When you add 4" lift springs the lift causes your pinion to rotate up
when you put the shims in thick to the rear it points the pinion up but causes your steering arms to point down (laymans terms here) making your steering even more - .
With your lift you want the shims thick to the front to push the angle back down so you steering is close to the stock +1 again?
Make sense? no? I usually suck at explaining things anyway :D
UNO_RACING said:
Poser,
Later
UNO.
and all of these goodies are desigend to work with a stock manual or power steering gear?
What style of coupler or adapter are they providing to make that connection between the stock manual or power steering gear box?
As far as AFTERMARKET steering columns go, I am aware of the pieces that you are talking about.....however, I fail to see how this is applicable to installing a later model STOCK steering column into an earlier truck...
:beer:
74fj40 said:
makes sense but i thought that you wanted the pinion angle to be straight with the drive shaft?
Not unless you are running a CV front or rear driveshaft....
The output flange on the transfer case and the pinion flange need to be within a few degrees of the same plane...
I installed a 76 column in a 72. Used the existing bracket attached to the 72 column to trace out a template. Cut it in half, bolted it in place around the 76 column and in place to the 72 firewall, then welded it up. No cutting firewall, free if you pick up the 1/4" plate from floor.
By the way, on my OME install the thick part of the shim went forward.
