Buck season here in So. Jersey always seems to take something out of my rig each year. This year, other than my front bumper which I just replaced with a Slee Short Bus. I lost the cover to my rear window vent. Has anyone had to replace one of these?
IIRC they are not cheap ~$80. I would try to glue/silicone yours back together if you still have it. You might want to seal up that vent assembly while you are at it. There is a writeup on here somewhere and it is a common spot for water leakage.
If you go for the ebay chrome set I guess it could be $80 for everything... But actually anything in this set, apart from the vents, is almost useless...
I wouldn't recommend sealing it, that is the rear vent for the full time flow through ventilation. The system responsible for preventing carbon monoxide, etc from building up in the rig.
Just replaced it. Pull the interior cover off from inside. I removed the jack cover and all else connected to get the quarter cover off. There is one small bolt to undo, then just pull it off. There are two plastic connectors that hold it in place. Put the new one in place, push to connect to the fasters and tighten the one bolt CAREFULLY or you'll break it. Not a real pain but an expensive piece that should've been made of metal in my opinion. Paid $80 for it from cruiserparts.net.
Thanks for all of the input guys. Sorry I haven't responded earlier but I never got an email stating this thread had been answered and I'm still deer hunting.
There will be some pics of the new Short Bus bumper posted as soon as I put the winch on it. Just got it the other day.
By the way thanks "vasellers". I think you've given me the information I was looking for. I was still wondering about the gasket that was under the louver. I lost most of that too. Would silicone take care of that or should I replace the gasket too? I haven't pulled anything apart but from what I can see with all of my gear still in there is that I don't seem to be leaking.
I have just finished repairing a leak in mine and I used silicone as I learned from a thread on leaking "slider window". The louver is more of a nice looking piece that just covers the vent. As long as your vent is seated well and not letting water in then you will be fine. Make sure the clip and bolt holes are well protected as water was leaking in through mine as well. There is a stock rubber grommet that may have fallen off the bottom half that the bolt goes through which stops leaks as well. I used silicone to stop the leaking so far so good!
