Harsh reving idle in reverse
When ever I put my car in reverse the rpms drop to around 500 and the engine revs up to about 700 and back down about every second. And when I take my foot off the brake to go backwards, the car moves in short bursts directly related to the increase of rpms. When I turn the ac on, it raises the rpms which therefor stabilize the rpms and I can back up like normal. But this doesn't always happen, and the ac won't affect it at all. Does anyone know what can be going on and causing the problem??
Thanks
Thanks
You have a tear on the bottom of the intake plenum.
Is it possible for me to do on my own, or do I need to take it in to get it fixed? Also do u know what a normal rate is to fix it @jonheld
also, would it be the actual plenum itself or its gasket? or maybe both?
The intake plenum is the big fat black tube that runs between the air filter housing, the AFM (air flow meter) and the intake manifold.
It is common for the tubing to become brittle with age and crack at the bellows (ribbed) section just before the intake manifold. This allows unmetered air to enter causing rough idle. It can be exacerbated in reverse.
It is easy to remove and replace.
