I have a 78 model 40-series that I keep topless most of the time. I have owned a mini-warehouse facility for the past 10 years so when it was off, I had a place to store it away from home. A few months ago, we got a sales contract on the property so I had to go pick up the top. I put it back on for a few months during the winter but the family loves it being topless so I pulled it off a few weeks back. After sitting it in my garage for a few weeks, I tried to come up with a solution for storage in my standard size residential garage. Full disclosure, my ceiling is over 8' in the garage so that helps.
My neighbor told me he had a hoist that he had never used and I thought I would try it. I think it is rated for 200-250#. At first, I hooked the rubber coated hooks directly to the side of the top and thought I had found a quick, simple solution. After getting it up off the ground, I realized that the pulley mechanism was digging into the side of the top.... not good.
On to plan B. I decided to try a lift sling. HF had a 6' on sale for $10 so I bought one and this past weekend I tried it out. The 6' sling will likely only work of you have wing vent windows so if you don't, you may need a 8' or 10' lift sling. Tree saver may even work. I also bought some 2x4 lumber to span the ceiling joists to spread the weight and to make sure my eye bolts had good anchor points in the ceiling and wall.
As you can see in the pictures below, the 6' worked great and the cheap amazon pulley system worked great. I would pull the pulley rope until it started tilting forward, then would pull the large ratchet strap on the front of the top to level it out. I basically walked it up about a foot at a time until I ran out of rope and strap. The green strap under the front side of the top is simply a safety strap that while possibly overkill, makes me feel better about walking under it.
The headliner portion of the top is probably 8' off the garage floor and I have my 40 pulled under it. Because of the layout of the ambulance doors, I can still get to my workbench, hanging wall storage, toolboxes, etc. I am 6'5" so I couldn't walk under the side without ducking but I imagine they are almost 6' off the garage floor.
It may not be the best solution but if you have a standard garage, this may be a good, cheap solution for you.
Please excuse the mess in may garage. The other side of the garage is clean, I promise...
