Hard top weatherstripping
Virginia Beach
Was looking for quick advice on installing weatherstripping for the hard top.
I am trying to bolt the sides bown but the new weatherstripping seems to cause a misalignment and the 10mm bolts don’t all want to go straight in.
I’m using the SOR kit. Thanks
You should be able to place a small screw driver in there and move the gasket. If the holes are not aligned then you can do the same in the next bolt hoke and apply gentle pressure in the direction you need the top to move.
I used electrical tape every 6 inches or so to hold my gasket in place. then remove the tape once I had all bolts in loosely.
Small Phillip’s head screw driver to line things up. Finger tight screws until all screws are started. Patients will get you across the finish line.
