Hard top reassembly???
Ok I disassembled my hard top at the begining of summer and broke off many bolts....yeah!....but thats not what I'm asking about here I can't seem to get to parts separated from the lid and I need to in order to replace the seal....the two sections giving me trouble are the pieces above where the doors are I've got pics to show where I'm talking about here:
my.php
[/URL][/IMG]
and here:
my.php
[/URL][/IMG]
how do you get these pieces off I can feel the bolts from underneath but can't get to the heads because there inside of the rail....does it come apart somehow? I don't know if anyone knows please let me know
Thanks
Brandon
Been there and my guess it you haven't removed all the bolts. Some are impossible to see and very difficult to feel. Take your time and it'll come apart. You'll get good at drilling/retapping the many broken bolts.
Yeah I've gathered on the drilling and retapping yeah I don't know how did you get that section off if you look at the second pic I've got the side bolts out of that part where it looks like it might come apart but it's solid and doesn't budge.....do you remember doing these?
Thanks
Brandon
The front door headers are two pieces. Remove the exposed screws and slide the outer piece off (slide it towards the rear of the top) to expose the bolts that connect the inner piece to the fiberglass top.
The two pieces might be somewhat rusted together. Tap the outer piece gently to the rear to get them apart.
Hey i've got a problem that I don't quite know how to solve....I was trying to drill and extract some of the broken off bolts on the lid of my hard top but I broke off a drill bit in one and broke a extractor(easy out) off in another....I don't think I can just drill through these b/c they are a harder metal or am I wrong.....any suggestions would be great
Thanks
Brandon
new ones
If you get to the point that you need new ones let me know, I make them.
Paul
QUOTE=Macgyver5]Hey i've got a problem that I don't quite know how to solve....I was trying to drill and extract some of the broken off bolts on the lid of my hard top but I broke off a drill bit in one and broke a extractor(easy out) off in another....I don't think I can just drill through these b/c they are a harder metal or am I wrong.....any suggestions would be great
Thanks
Brandon[/QUOTE]
Thanks
Brandon
You obviously didn't get your screen name working on Land Cruisers, did you? :rolleyes:
I just couldn't resist.
Not being able to replace a single bolt here and there will not be a big deal on the top. Just be patient and use something like WD-40 to drill and tap. :idea:
Try some stuff called Dev-tap works really well. I in the same place working on a new top in which I just broke off all of the bolts on one side of the top.
later
Ryan
Yeah I tried the chewing gum and paperclip method but got disappointing results so I came to my friends here @ ih8mud and I've yet to be disappointed
Don't use too much speed on the drill, It will "work harden" the bolt. It heat tempers the surface of the metal being drilled kind of like an annealing process also don't use too much pressure on the drill, same thing.
Been there. The problem with a bolt that breaks due to rust, galling of the threads or whatever is that no extracter in the world is going to get it out and you end up where you are. The only place I have found extracters useful is when you overtighten and break the head off or something similar. The bolt broke because it won't turn. What makes you think an easy-out is going to work? Break 'em off in the hole and you are fawked. I can't remmber the last time I even took them out of my box. Having been exactly where you are you have a couple options. Certainly you can leave a few out as Ed suggests. I drilled them out completely and rethreaded either with same M6X1.0 as the standard bolt or slightly larger and goto a 1/4X28 or whatever is the next larger size. You can do it..it is just going to take time. be sure and drill dead nuts on the center of the broken bolt or you will have a bigger mess on your hands.
Well I broke off like 11 or 12 of the bolts and I've drilled out all but the 2 that have case hardened metal stuck in them and now I guess I'm going to try and drill those out...and I know what you mean about being on center I've got one that came out kinda oval shaped not sure if I want to go a size up one just it or go ahead and do all of them so they match....also in the back corners are the holes smaller than the rest? they kinda look like it but I'm not completely sure....oh well thats the update!
-B-
