hard top install on 40
Decatur, Ga
First time install-
Do I need to remove the roll bar in order to mount the hard sides and top?
On the side peices, there is one large bolt, close to the front doors. What do they bolt onto to?
Thanks
droopydawg said:
First time install-
Thanks
Do not need to remove roll bar. Im guessing the large bolt in close to the front is the pole that goes down in the hole of the tub.
I know about the pole that goes down into the tub, but thanks. This is actually a bolt, I am guessing a 14mm or 15mm, below the big main side window and about 10 inches in from the front end of the side piece. i will look to see if I have a pic. This bolt faces the inside of the passenger compartment.
Hard top shouldn't be a problem, 3 guys make it easiest but 2 will work. Probably weighs 250 pounds or so and has an aft CG. If your posts are still long I've found that if you chop em down to about 3 inches it makes things easier and less likely to run a nice gouge down the side of the paint. Not sure about the big bolt. Did you say your top is in pieces or all together still?
Pieces. 2 sides, roof and the 2 rear doors. Install it all separately. Once mated all up, maybee I will take off as one piece when the weather warms up again.
I have been cleaning up the rust and rust proofing the mating surfaces. Will finish it up this weekend and drill out a few broken bolts left from PO, then order all the weather striping and install. Pretty easy.
only big bolt i can think of is on the section that the post drops into...on my cruiser, it's what holds the straps for the doors (canvas straps for softtop model) :confused:
What year of truck? I cant think of any bolts on the lower edge of the sides, but there are 15mm bolts on the upper edge of the sides, about 10" back. Ive been told these are bolts for seat belts on Non-US trucks without the rollbar. Ill look at mine when I get home, I have a 79' and my buddys 74' is at my place too.
Hodag
If your top is around a 1977 model the big threaded hole is for the seat belts. The shoulder type. should also be a threaded hole above it near the top. I won't cut the poles off if you didn't have to. There is a plate inside the hole in the tub that the pole fits into. Helps brace the top. If you try to compress the end of the pole a little this will help. Look down the hole with a flashlight and you will see the brace I'm talking about.
John
In picture attached, bolts are on the other side of the yellow circle.
It is a '78 FJ model.
I don't have the top in town but if I remember there is a plate welded in that area with a threaded hole at the top of it and non-threaded hole towards the bottom. Your main piece of your seat belts would bolt to that. If it does't have the two holes then I don't know what it is. The non USA cruiser didn't get rollbars at least not all of them. So this is where they mounted the seat belts. I don't know if all the tops were imported this way, but I do have a rear vent window top off of a 77 or 78 that has this plate. I have the rear doors too and they are for a 78 or earlier cruiser.
John
Like I said I don't have the top in town but now that I think about how the seat belts mount the threaded may be the bottom one. but if one is threaed and one is not this is for the seat belts.
nuclearlemon said:
is there a reinforced section there? i think thats a lower shoulder belt mount. some mounted off roll cage, some off top.
Yep, that must be it.
Thanks for all the replies.
Now for my new thread.
The big bolt is for your seat belt retractor gizmo. It mounts with one bolt aiming up to where the strap goes through a hanger higher up on the side that mounts with another large bolt directly above the lower one. :)
