I've been driving my FJ daily for years and never had any issues to speak of but a couple of weeks ago my poor FJ40 started acting up.
I was doing some groceries and on my way back home shifting into gears became more difficult. It worsened quickly to the point where I couldn't use second anymore. And sometimes it just popped out of the gear. I never experienced that before.
I managed to get home and and diagnosed that the clutch master or slave was to be replaced. No big deal so I ordered the (oem) parts at CoolCruisres in Texas and waited for them to arrive. (a great source for parts btw).
While waiting I thought it might be a good idea to replace the manifold gasket.
It started to leak a bit when cold, making a sound like a train, tshk,tshk,tshk, if you know what I mean.
All parts arrived and I attacked the clutch first. A half a banana job. I took it for a test drive and the problem was still there. My diagnose was wrong
I suspected that there might be something wrong with the shifter itself, so I opened up the top and noticed some dirt (or at least that's what I thought). So I cleaned it all out, did some googling and found this thread The dirt was the disintegrated plastic seat (the blue ring in the other thread
So I got a new seat and boot (it was torn) at the Toyo dealer, put it in and wha-da-ya-know, it shifts like new again.
So now I have a spare master and slave clutch cylinder because the replaced parts where in perfect working order.
This is what was left of the seat:
So then I started on my manifold gasket problem.
I really had a hard time accessing the bolt near the fire wall. There is just not enough space. There is a heat shield that when taken off might give me some more room to work, but (of course) one of the bolts stripped so taking it off wasn't possible.
I finally managed to loosen all the bolts (the last one while sitting on the battery (lol).
I then cleaned up the surface using some fine grid sand paper, put the new gasket in adn bolted everything down.
Then started her up..... the leak was worse the before
I am guessing that the exhaust manifold is slightly warped. Not much, because when the engine heats up the sound goes away.
I loosened the bolts again and tightened them in a different order. starting in the middle, but that didn't help. I might need to machine the manifold. But I am not looking forward unbolting everything again so I will try the 'C trick' (ring cut in half or a stepped washer) described here first. Wish me luck.
They are soft like butter and even sliding the manifold over the threads was enough.
