Hand Throttle in a 40
Madison, MS
Multiple searches provided good info, but little detail. Here are my questions...
What is the best/easiest/safest hand throttle set-up for a 40?
Can an FJ62 hand throttle be adapted to a 40? Who has done it?
Any detail on bicycle brake handles/cables adapted to 40s for a throttle?
Pics of the throttle at the dash, tranny shifter, gas pedal, and carb would be great.
I also checked the Tech Links, but found nothing. Has anyone done a write-up on hand throttles?
Rig in question is a 6/77 FJ40 with stock 2F carb that is soon to have OBA. I'm also hoping for a smoother crawl while bouncing around on the trail.
TIA
Thanks Ige! I don't know how I missed that?!?!?
I would use a bike shifter instead of the brake handle so you can set it to a specific RPM and not have to hold it. I used one and really like it.
Thats a poor mans cruise control.
I highly recommend one of these. It's a sweet setup - screw it in or out for "infinite" adjustment, unobtrusive, good quality, and Nathan is a good guy. Used an existing hole in the dash. Had to customize the bracket and spring at the carb.
Nathan's throttle cable
Options
I'm considering going with the kit from SOR. It has a new pedal and all the mounting hardware brackets. Costs a bit more, but it is stock Toyota equipment.
For those of you with later models, how do you mount Nathan's kit to the carb? Do you have to build something custom or just drill a hole in the existing throttle bracket? I know I have a pull knob in the dash that doesn't work, so I could just drop Nathan's kit in.
tx4guns,
Make sure that SOR has ALL the parts in stock. The PN on the website that shows the kit is not necessarily complete. I was not very happy when I attempted to get the complete kit with the pedal. No pedal showed up and I got the run around.
The dash mount ones are ok, but if you are strapped in w/ a 4pt harness or are off camber and the 3pt is locked the dash mount is hard to reach. I prefer it to be on the tranny shifter for ease of use.
This is the one I am using. It's a bicycle shifter. I like it on the shifter because I can keep one foot on the brake, the other on the clutch, and still work the throttle as needed. It also has a friction screw on it so you can set and hold a specific RPM, good when I'm winching or using my on-board air.
Dash or shifter? I think it depends on what you plan to use it for. If it is strictly for winching, welding, or jumpstarting, then the dash unit is the one you want. If you are needing a bit of added control while rockcrawling then the shiftlever is the more useful of the two. Personally, I like both. I use my finger throttle on the shifter when I need all three pedals and only have two feet. I use my dash mount throttle when I just need to bump my idle up a bit. I have my finger throttle set so that in a complete panic rev it will only do 3000RPM in neutral. That way there is no chance of engine damage due to over-rev. Sometimes I use my dash throttle to keep my foot from bouncing on the throttle in those bumpy small boulder sections between obstacles. It can also be used as a high idle to help prevent stalling on difficult climbs.
Lots of great info. Thanks very much to all who posted. Now lets see some pics! Pics of dash mount, carb linkage mount, etc. Any do's and don'ts??
Thanks to Capt Jim for the pics on the shifter. What length shifter cable did you use. If I walk into the bike store, what specifically do I ask for?
Thanks again.
These are stock on BJ4* series, used for cold starts on the diesels. Simple throttle pull and cable going to the accelerator linkage... maybe find a Canuck who has a rust bucket he's parting out...
B
Thanks again.
I'll get you a pick of the other end of the cable hook-up later today. Cable length can be cut by you to any length. Buy the lever and cable separately, get about a 6' cable, install at shifter and route it to the mount on the engine, then cut it off. All you will need to fabricate is the mounting bracket on the engine.
Pics
poor man's version
I used my choke cable ( electric choke weber installed and manual choke cable
on my 72 was just "there" on the dash) and attached it to the carb with
chain links so as to not effect the throttle operation. I set the cable pull
so as to not exceed 2500 r.p.m. when pulled all the way out. It's great
for bumping the idle for those cold mornings/winching/shower duty etc.
Cost? 10 cents for the chain. Took 10 minutes to rig.
hammerhead said:
Dash or shifter? I think it depends on what you plan to use it for. If it is strictly for winching, welding, or jumpstarting, then the dash unit is the one you want...
There is another option!
I added a hand throttle after I installed my underhood shower and welder. I originally had a bicycle shifter on the tranny shift but changed that set-up once I really started to use it. I found that I rarely used the in cab throttle to control engine speed while driving, but used it more for working on the engine, welding and showers.
Since the control box for the welder was under the hood and hook ups for the shower were on the front bumper, it made more sense to me that the throttle should be outside where I could easily control rpms without continually jumping in and out of the cab to make adjustments. It also helps when working on the engine and you need to control engine rpm.
So... I mounted mine on the front bib under th drivers headlight. My control box for the welder is just above the driver's headlight so I can easily adjust the voltage. This set-up doesn't have the bling that a tranny shifter does but for me it is more practical.
Does anyone have pics of Nathan's Throttle at the dash and the carb?? What mods are required at the carb. Someone mentioned bracket and spring????
If I understand it correctly... twist handle to right to increase RPM and to left to drop RPM? Or is it pull out to desired RPM and twist to hold that speed?? Twist and push in to turn off throttle?
Thanks lots!
