Had an alignment done w/??'s
Washington, MO
Left Front: Camber: (Min 0.25 Max 1.75) Actual 0.3
Caster (Min 2.00Max 4.00) Actual 1.3
Toe (Min .05 Max .15) Actual .09
Right Front: Camber: (Min 0.25 Max 1.75) Actual 0.1
Caster (Min 2.00Max 4.00) Actual 1.7
Toe (Min .05 Max .15) Actual .08
Front:
Cross Camber Actual .01
Cross Caster Actual -.4
Total Toe 0.17
Set Back 0.63
Left Rear
Camber Actual -.4
Toe Actual 0.87
Right Rear
Camber Actual -.1
Toe Actual 0.30
I’ve been searching and searching and can seem to locate an alignment interpretation thread. I did install the OME CC bushings. But after my tire wear fiasco, I had the alignment double checked. The toe was in spec. But the Caster and Camber are out of spec according to the printout. Are these specs the correct numbers? Do 3 degree caster bushing net 3 degrees of correction? The truck still drives straight. There is some float in the steering wheel. Should I do the old “drill, weld and washer method” to fine tune the caster? I think some settling has occurred since the original OME lift and alignment. If I were to raise the front back up a little bit with a spring spacer, how does that effect the caster, better or worse? Can someone point me to the geometry of alignments thread. Or reference a book to read so I can understand these reading more.
I had the bearings replaced about 3 years ago. During the tire rotations I usually give the front end a little shake to check for any play. At what point of bearing wear would I physically be able to notice? Would I feel any play in the hub is what I'm asking? Or when I feel play is it too late?
With respect to lowering the caster reading, would 3 degree caster correction or other cc bushings, net 3 degrees of correction? According to the spec numbers on the printout, 3 would be too much. I’m attempting to look double check the spec. as provided to me by my local dealer.
If I wanted to get more positive caster, I guess a rear drop bracket may be the answer, or better yet slight modification to my existing bracket without the ground clearance sacrifice.
It appears to me that all trucks react differently to suspension modification.
The post-lift alignment results seem to be all over the board. I need to do some more research for this specific problem if I truly have one. Or should I leave well enough alone.
What are you trying to resolve? The tire wear issue? If so I don't think caster has any effect on tire wear whatsoever.
The first questions are what are you trying to fix and how does it drive? From the numbers I would guess that it drives well?
If your looking for tire wear issue, I don’t see it. More caster will if anything very slightly increase wear, if you have OME CC bushings, changing them to 3 degree bushings will only change it about 1 degree. Is the toe reading in degrees, mm or inch? If inch it’s on the high side, reducing it will slightly reduce tire scrub, very slightly increasing tire wear, gas mileage, the downside maybe slightly lower high speed stability.
The bearings should be preloaded, i.e. no play, if they have play attention is needed. If they have been recently serviced, adjusting, resetting the preload is most of the time all that’s needed. If they are due for repack it’s best to do a complete take apart, inspect, repack, service. Most of the wear that causes play in the wheel bearings is the washer, if it has a groove, it needs to be replaced. Most bearing “wear”/ break in, happens when new bearings are first installed, as long as used “broken in” bearings are reinstalled in the same location, on the same races, they will maintain their adjustment better than new bearings.
If your happy with the way it drives, I would leave it. If your thinking of doing the washer mod or Landtank’s plates to get more caster, I would push those stiff CC bushings out and replace them with stock bushings.
It drives good, like the 73 chevy p/u I had in HS. It drives nothing like the wife's SUV.
I don't mind, I'm used to it. When the wife drove it the other day, she said she was all over the road. For that reason I had the alignment checked to make sure that I hadn't conditioned myself to driving with some sort of querk.
The toe is in degrees. I'm not sure if I should leave well enough alone or mess with it. It's my daily driver which is why I like keeping on top of things like the brakes and handling. If it were only a weekend trail rig, I would care alot less.
I personally prefer negative toe for the front. The positive toe with bigger tires can make it feel darty. As far as all over the road it could be due to the low caster. How well does the wheel recenter itself?
Drives straight with hands off of the wheel. Darty/loose at Hwy speed.
I personally would try some toe in. After I had my truck aligned once it was darty. I toed it in a bit and it improved things tremendously. The downside of toeing in is increased tire wear. Oh and I would also make sure all the tie rod ends, knuckles, wheel bearings, etc are tight. Those will cause loose steering.
