Output Shaft!!!!And here are some pics to visualize what is going on inside the case cover when the shifter has locked in place because the tranny was set on it's nose. Gravity drops the reverse idler gear, which causes the reverse shift fork to jump in reverse... locking the shifting mechanism. The reverse shift fork can also be moved by hand if the case cover is off. Just push it all the way in until it snaps in place.
Through the top? Basically just remove the shifter cane and manipulate the shift forks through the top of the housing?Even when the reverse has slipped I can get it with a screw driver through the shifter housing.
Sorry, I’m having trouble visualizing this. You are placing the screw driver down into the reverse gear hole to manipulate the reverse shift fork?To "fix" this problem you pull the reverse gear light sender and put a screw driver between the shifter and the front part of the hole. gently pry back and the reverse fork will now pop back into place freeing up the tranny, sometimes you need to gently rotate the input shaft back and forth.
