H42 4 Speed
Manahawkin, NJ
I purchased an H42 4 speed (1977) to mate with my 3 speed transfer box. Upon arrival the shift lever was not installed, so I am trying to insert to test the transmission however it is not shifting. The seller stated that there is a sequence of alignment one needs to complete before just popping the lever arm in. Can someone explain as I want to test this trans before installing. Below is what he told me to do, but I have no idea what that means. Please help?
"You have put the shift lever in the trans. with it in reverse as well in neutral. You will have to take it back out and line up all three shift rails with a screwdriver before installing it back in"
The transmission needs to be in neutral. Look in the top and line up the shift plates.
JP
JP
I don't see exactly how to get the trans in neutral with a screwdriver. I don't want to damage anything but tried to move things front and back. Nothing seems to be moving with a screwdriver. Does anyone have an video on this or photo example?
JP
See the pic, it is in this position and nothing is moving forward or back with a screwdriver?
Take a look at this thread 4 speed shift seat replacem it may help.
JP
unfortunately that doesn't have any pics that show what is neutral and how to adjust.
Thats in neutral. Does the shift cane fit in the slot. If not you may have a wrong shift cane.
JP
JP
Yes, it fits in but nothing moves. I feel like it slides right in place but trying to move the shifter around in any normal gear doesn't feel like anything is doing anything. so maybe it feels like its stuck or seized idk but seller on eBay has good reputation and said good working condition and claims it works. i am putting some weight into it too and nothing
Also with the shifter out of car in that exact position when I turn the input shaft the output shaft moves, so NOT SURE how this could be neutral
It does not take much effort to shift gears. If you hold the out put shaft and turn the input shaft you should be able to turn one and not the other. I would remove the top cover of the transmission and inspect the gears and internals.
JP
Make sure all three are in the center position. Edit: and not all forward or all back.
Here’s a pic with the top plate removed which allows you to see the three rails. Each of the three rails slide fore and aft. Each rail has detents on top of it and a ball under each of the three springs in the pic, hold the rail into one of three positions. The center position being neutral. Just move each one back and forth with a screw driver and find the center position for all three.
Good pic @Steamer It looks like he may not have all 3 lined up !!!
JP
Ok, thanks. I see now, the far right shaft wasn't aligned. I was able to move that and align, and shifter slide right in and moves into 2nd, 3rd, 4th, and Reverse smooth, but no matter how hard I try it won't shift into 1st. I moved the input while trying as well and nothing. any ideas on how to get into 1st gear or what issues could be?
Great! & welcome to the group.
As a youngster in the 60’s I used to drive my go-kart on an abandoned stock car track in Manahawkin.
Gotta love the Jersey shore. Grew up in AC.
Nice. only problem is the winter. Hey you will probably know this answer, so I'll give it a shot. I bought the H42 to swap out the 3 spd in my 1972. It has a 350 conversion from previous owner. I am rebuilding that now and will order an adapter from the 350 to h42, however I am under the impression the h42 will mate right up to my original 3spd (1972) transfer case. I see a few saying you need a gear swap out in the 3spd case, is that correct, and do you know where to get it or what it is called?
Glad it works :cheers: and welcome:flipoff2:
JP
